starts only ones the battery terminal remove and reconnect
1999 JEEP GRAND CHEROKEE
2 MILES • 4.7L • V8 • 4WD • AUTOMATIC
ANEESHBABU
  • 10 POSTS
Hi my jeep only starts when the battery terminal disconnect and wait for one mint then reconnect then it starts . i found there is a code P0340. i changed the camshaft position sensor but same again i checked the wire connection from cam sensor to TCM its good. i found that in the not starting time when we crank there is no spark coming in the spark plug. what shall i do. should i change the TCM. ?
Sep 24, 2015 at 12:48 PM
HMAC300
  • 48,601 POSTS
try resetting your security system on the truck. if no manual look online.
Sep 25, 2015 at 12:07 AM
ANEESHBABU
  • 10 POSTS
ok i will try that. but there is no security check light on in the meter console
Sep 25, 2015 at 7:54 AM
HMAC300
  • 48,601 POSTS
it doesn't have to be it does screwy stuff like that occcasionally
Sep 25, 2015 at 8:01 AM
ANEESHBABU
  • 10 POSTS
Hi
i couldn't find where it in trunk , can you tell me where it is located in the trunk please
Oct 16, 2015 at 1:03 PM
ANEESHBABU
  • 10 POSTS
Hi i find out one more thing that when the non starting condition the camshaft position sensor not getting that 5 volt input, i think thats why its not generating the spark.
Oct 16, 2015 at 1:13 PM
HMAC300
  • 48,601 POSTS
it said the TRUCK not Trunk in my reply. scan for codes then to see if cam sensor or wiggle test connector see if that is bad.
Oct 16, 2015 at 11:50 PM
ANEESHBABU
  • 10 POSTS
Hi
i checked the cam sensor connector and its wire both are fine . now i changed the PCM and TCM . unfortunately no change to the problem it acts same way, only starts ones we remove and reconnect the battery :(
Oct 17, 2015 at 8:46 AM
ANEESHBABU
  • 10 POSTS
can i try one thing , can i give a 5 volt from a different source so it won't get cut . will it make work the cam sensor?
Oct 17, 2015 at 8:59 AM
HMAC300
  • 48,601 POSTS
replacing the pcm without programming security will not allow it to start a local pro has to do that no matter what the idiots behind parts counter say....... have it scanned for codes to find the problem
Oct 17, 2015 at 9:00 AM
ANEESHBABU
  • 10 POSTS
well i bought one cpm after programing my vin number,
Oct 17, 2015 at 9:02 AM
ANEESHBABU
  • 10 POSTS
the only code it showing is P0340. this is only shows when in the non starting situation
Oct 17, 2015 at 9:04 AM
HMAC300
  • 48,601 POSTS
code 340 is no cam signal at pcm you will have to check wires for a short in system or broken wire from there. I have no further comments or suggestions for this problem.
Oct 17, 2015 at 10:06 AM
ANEESHBABU
  • 10 POSTS
yes its a non cam signal situation . there is no signal coming from the cam to the cpm because there is no power going to cam sensor its only going when the battery resets. i didn't find issue with the wire i checked the continuity with the multimeter. it looks fine. by the way i have a diploma in automobile and i am a electronics engineer . but i have no wiring diagram of this vehicle . if you cannot help further it is so sad
Oct 17, 2015 at 11:28 AM
ANEESHBABU
  • 10 POSTS
and i was sure that its not a broken wire situation because if its a broken wire situation the vehicle won't start ones the battery resets
Oct 17, 2015 at 11:30 AM
