Starts, idles, then shuts off
122,985 MILES • 3.8L • V6 • 2WD • AUTOMATIC
KRYSTAL HURLEY
Hello, me and my husband have the GTP model. Our car ran perfect, ran fine, drove fine. We already knew about the check engine light from when we bought the car. my father hooked up a scan tool to diagnose it. It came up for the EGR Valve, which we were told about when we bought it. My father then decided to clear the code, not sure what else he did. Now every time we start the car it idles for like five seconds sometimes less, then shuts off. We tried a few times to start the car, and the same thing happens, it starts, idles for a few seconds then shuts off. My husband was able to start it and drive it no problem to and from work before this. Thank you for any and all help!
Jun 25, 2017 at 10:33 PM
HMAC300
  • 48,601 POSTS
if you have another key try it (not a new key it) may be the diode is shot in yours as it sounds like a security problem. otherwise it will need a mechanic to scan and see if it is the security system problem or not.
Jun 25, 2017 at 11:49 PM
  • 55,808 POSTS
We should start by reading the codes to see what else come up. Here is a guide that will help you.
Also, check the oil level in the engine. Some of these engine have an oil pressure cut off switch that activates when the oil pressure is low.
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jun 26, 2017 at 2:26 AM
