Starts great uphill?
180,000 MILES
SKY74
It starts instantly in the morning when cold but once it's been running it takes two, three five second cranks to start, even if I let it sit for a few hours. However, if I park it facing uphill it will start right up instantly.
Mar 23, 2023 at 2:08 PM
  • 55,732 POSTS
I have seen a weak fuel pump cause this issue, but to be sure let's do a fuel pressure test. here is a guide to help with the instruction for your car and how to replace the fuel pump in the images below:
Fuel System Pressure (w/fuel pump running) .................... 379 - 427 kPa (55 - 62 PSI)
Fuel System Pressure (after fuel pump shuts off) .................... 34 kPa (5 PSI)
Fuel System Pressure Drop (after 5 minutes) .................... 14 kPa (2 PSI)
You can rent a fuel pressure gauge for cheap at the local auto parts store. Check out the images (below). Please let us know what happens.
Mar 24, 2023 at 11:50 AM
