starts cold will not crank warm
1981 CHEVROLET
1,000 MILES • 5.7L • V8 • AUTOMATIC
DOGMAN51
I have a rebuilt 350 CI Chevrolet that starts great when cold, but will not start warm. I have to wait twenty to twenty five minutes to restart when at operating temperature and then cranks very, very slow but it will start. it will run all day after the first start but the above starting issue is always the same. the engine only has about 250 miles on it. I have replaced the starter and alternator. I have replaced the temp gauge so I know it is not overheating. is it just a tight engine? Help!
Feb 6, 2017 at 9:55 AM
CARADIODOC
  • 34,416 POSTS
When the slow-crank occurs, measure the battery's voltage while a helper cranks the engine, then measure the voltage right on the large stud on the starter solenoid, again, during cranking. When measuring at the solenoid, put the meter's negative probe on a paint-free point on the engine, not on the battery. At the solenoid, put the probe on the stud or nut, not on the terminal crimped to the cable. Tell me what you find.
Feb 6, 2017 at 10:02 AM
DOGMAN51
the battery checked at 12.4 volts and the solenoid at 11.8 volts.
Feb 6, 2017 at 11:36 AM
CARADIODOC
  • 34,416 POSTS
Both of those suggest the starter is not drawing enough current. The battery's voltage should be getting drawn down more than that. One worn brush of the four in the starter can cause this. The starter motor is electrically two motors in one housing. When one part fails, the other will crank the engine too slowly and it will initially draw only half of normal current.
To confuse the issue, a GM or Ford V-8 starter will draw in the area of 300 amps at first. Once it is spinning, it generates a voltage, just like a spinning generator, that opposes battery current. That results in battery current dropping to around 225 - 250 amps once the starter is spinning. With half of the motor not working, it will draw about 150 amps initially, then, since it's spinning too slowly to generate that reverse voltage, current stays near 150 amps.
Those numbers are approximate, and it is why a partially-failed starter can be so hard to diagnose. The current draw for a starter with one bad brush is close to the same as for a good starter spinning at normal speed.
Assuming your replacement starter is okay, the next suspect is an excessive voltage drop across a loose or dirty connection. To start finding that, put one voltmeter probe on the positive battery post, (not the cable clamp attached to that post), and put the other probe on the stud on the starter solenoid, (not the terminal bolted to it). If you have GM's miserable side-post battery, you just have to put that probe on the 5/16"-head bolt and hope for the best. These two points are the same points electrically in the circuit so the voltmeter will read 0.00 volts. Now take that same reading while a helper cranks the engine. If there is any undesirable resistance in that cable and its connections, the results of that resistance will show up as a voltage reading. The maximum allowable is 0.40 volts in the entire circuit.
Do the same on the negative half of the circuit. Put one meter probe on the negative battery post and the other probe on a paint-free point on the engine block. 0.04 volts is the most you are allowed during cranking. If either reading is too high, we can narrow it down with additional tests.
Do you have a side-post battery or one with posts on top?
Feb 7, 2017 at 7:39 AM
DOGMAN51
your info is great but I must stop here so to not waste your time. this engine is in a chris craft cruiser and I cannot start it again. at this point I blew out all the antifreeze on the first test. it is winterized on a hoist. anyway it has top post type marine battery. the whole thing about this is the original starter/solenoid had the same problem with cranking and now so does the new one. your out of connection issues may be the next check. note this - on the first test I only let it idle for 20-30 seconds and the hard start was apparent. this is the first I've noticed it for such a short run and not wanting to start. the engine only has 106 hours on the rebuild. You probably don't have much input at this point so I will save all of this until april when I can put it back into service. I thank you for your time an knowledge to this point.
Feb 7, 2017 at 9:14 AM
CARADIODOC
  • 34,416 POSTS
I'll be waiting here. A starter circuit is a starter circuit, regardless of what kind of body is around it. Up to now, the voltage drop tests I described previously apply to any starter circuit on any engine.
If I didn't mention it already, measure the battery voltage, right on the posts, not the cable clamps, during cranking. The industry standard is it must not drop below 9.6 volts.
Feb 8, 2017 at 11:21 AM
