Starts can drive half a mile then shuts off and was not firing on all cylinders?
2004 DODGE TRUCK
187,000 MILES • 5.9L • V8 • 4WD • MANUAL
STEVEN GRIBBINS
  • 26 POSTS
The truck had a wiring issue where it wasn't firing on all cylinders, I continued to drive it till it just wouldn't start anymore. although it sounded like it wanted to so I took fuse box apart got it to fire on all cylinders and to finally start but only run for a ½ a mile then shut off will only run really bad if I pump gas really fast it has black buildup in intake.
Feb 11, 2024 at 8:43 PM
  • 55,104 POSTS
It sounds like the fuel pump is going out, but can you run the codes to see if any are stored?
Here is a guide to help:
Also, when the engine stalls, can you turn the key on without cranking the engine over can you hear the fuel pump run in the tank for about 5 seconds?
This guide can help as well:
https://www.2carpros.com/articles/engine-stalls
Please go over these guides and get back to us.
Feb 12, 2024 at 1:51 AM
STEVEN GRIBBINS
  • 26 POSTS
I put a new fuel pump in it when was able to stay running you could hear something in the valve cover clanging around and now that it only stays running a few mins I don't hear the clinging but the intake manifold is covered with black soot.
Feb 24, 2024 at 8:12 PM
  • 55,104 POSTS
Hmm, it sounds like the exhaust might be clogged, I would loosen the exhaust system at the exhaust manifold flange to see if that makes a difference. The engine will be i bit louder FYI. Also, this guide might help:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Also did you run the codes?
Feb 26, 2024 at 2:46 AM
  • 55,104 POSTS
anything?
May 11, 2024 at 3:20 AM
