Starts but won't stay running
129,000 MILES • 5.8L • V8 • 4WD
TRENNA LINDA AVALOS
I acquired a Bronco from a friend it's been sitting for 15 years so naturally a few things need to be changed fuel filter fuel pump spark plugs wires but my thing is when I try to start it it won't start unless it's Prime from the throttle body soon as you put your foot on accelerator it bogs out
Jul 28, 2017 at 9:21 AM
  • 55,808 POSTS
It sounds like the accelerator pump is not working in the carburetor. Remove the air filter and with the engine off use a flash light and open the throttle you should see two little streams of fuel going down into the carb. If not the carb needs to be rebuilt or get a rebuilt unit.
Cheers, Ken
Jul 29, 2017 at 5:16 AM
