Will not stay running?
284,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
JACKO3478
The vehicles start but when taking your finger off the ignition it shuts off. it runs just long enough for one to two seconds.
Dec 17, 2022 at 2:33 AM
  • 110,248 POSTS
Does the engine stall immediately after releasing the key from the start to the run position? If it does, that may indicate an issue with the ignition switch itself.
Or does it run for a few seconds in the run position and then stall?
Dec 18, 2022 at 3:09 AM
