Starts but then sputters and shuts off?
180,000 MILES • 3.5L • V6 • AUTOMATIC
MCARTER93
Also, no reaction from pressing on the gas pedal. What can it be?
Jul 27, 2023 at 6:48 AM
  • 110,246 POSTS
Based on your description, it sounds like the fuel pump may be failing. With that in mind, I would start by checking the fuel pump pressure. You will need a fuel pressure gauge for this, but most parts stores will lend one to you.
Here is a link that explains in general how to test it:
If you look below, I attached the manufacturer's fuel pressure specifications for this vehicle.
Let me know if this helps and what you find.
See pic below.
Jul 27, 2023 at 3:55 PM
