Starts but shuts off
90,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
STEVEGRIFFIN
Starts but stalls and any electrical demand will shut if off.
Nov 6, 2018 at 5:02 AM
  • 110,248 POSTS
Hi and thanks for using 2CarPros.com
It sounds like there could be a simple resolve to this. Most often, a weak battery connection will act this way. Take a look through this link and let me know if it helps.
As I said, let me know if this helps or if you have other questions.
Nov 7, 2018 at 11:47 AM
STEVEGRIFFIN
Well, every thing is new, battery, cables, cleaned all grounds still the same. While checking power at fuel pump, I noticed the 12 volts went away after start, where the heck is the fuel pump relay on this heap? The truck is a 1986 cab and chassis. Thanks a lot Joe it is nice of you to help. Google YouTube show newer trucks but zip on 1986.
Nov 7, 2018 at 12:54 PM
STEVEGRIFFIN
Hey Joe, I introduced 12 volts to the fuel pump, key in run position and away the turd went. It is kind of looking like I need an ignition switch. Would you agree? Thanks for the push.
Nov 8, 2018 at 6:19 AM
  • 110,248 POSTS
Welcome back. Check all fuses and the relay. I have attached pictures of the relay and fuse locations. Chances are it is not the switch.
Here is a link that discusses how to test a relay:
Nov 8, 2018 at 11:29 AM
STEVEGRIFFIN
Hi Joe, yes you are right. there is power everywhere. Turns out a circuit opening relay and the ground wire are the problem, they should have named it gremlin switch to cut fuel. Thanks Joe
Nov 9, 2018 at 9:16 AM
  • 110,248 POSTS
Happy to help. I am glad you found the problem.
Let me know if you need any other help.
Nov 9, 2018 at 12:06 PM
