starts but will not stay running
200,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JOHNORPEN
  • 5 POSTS
This engine and transmission has been installed in a 1951 Chevrolet. I had it running well last time I started it about a week ago. Now it starts as it should but shuts off within a few seconds. The fuel pressure is good. It doesn't run long enough to get any real info from my test equipment and hasn't set any codes. I used the stock engine and transmission but removed all the emissions systems. I have a tuner that allowed me to turn off VATS, EGR, and other non-essential items. The car ran very good last week.
Jun 24, 2020 at 9:24 PM
Good morning,
Do you have the key with the resistor in it?
Does the security system still work with the ECM?
Jun 24, 2020 at 9:28 PM
JOHNORPEN
  • 5 POSTS
The security system is disabled in the computer. As I stated, it ran good last week and I haven't changed anything on the engine, computer, or wiring.
Jun 24, 2020 at 9:41 PM
Okay, does it start right back up or do you have to let it sit for a while?
If it starts right back up, it could be electrical. The module could be the issue.
If it does not, it could be fuel related. The LT1 motor runs around 41-47 pounds. Do you have this?
I would also check the distributor. Common for the cap and rotor to get wet and cause this type of issue.
Jun 24, 2020 at 9:57 PM
JOHNORPEN
  • 5 POSTS
It is a project vehicle and has never been out of the shop so I know it isn't moisture related. Fuel pressure is 48 psi with the vacuum line disconnected. It starts every time I try it and then shuts off, no waiting required.
Jun 24, 2020 at 10:29 PM
This does sound like you are losing spark.
Can you test the power to the distributor with the key on? I am wondering if you have power in the start position and not in the run position.
Do you have a scope that can monitor the signal from the distributor to the ECM?
Jun 24, 2020 at 10:40 PM
