My car starts, idles for about ten seconds then cuts out
142,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
LOUISVZ
My car starts, idles for about ten seconds then cuts out and will not restart only in the morning after standing overnight when it is cold. Otherwise it would start and run normally. Last night I started it at about 21:30 (very cold outside after I did not touch it for about six hours during the day)) and everything was fine. Drove it no problem. Next morning at 06:00 started first thing, idle for ten seconds then cuts out. Will not restart. I poured some gas into carburetor and it starts until gas runs out then cuts off and will not restart. Seems like fuel starvation, but why only in the cold morning? Even operates fine in cold evening.
Jul 5, 2018 at 7:18 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
It sounds like you might be possibly having a fuel pump related problem. I suggest having your fuel pressure tested to see if you have low/weak pressure. Danny-
May 21, 2021 at 11:02 AM
RENEE L
  • 1,260 POSTS
Hello LOUISVZ,
Thank you for visiting 2CarPros. Here is a link to an article from this site with step by step instructions and pictures explaining the process of checking the fuel system pressure, regulator and fuel pump in less than fifteen minutes:
If you need further assistance please come back to the site we are always happy to help.
Kindest regards,
Renee
Admin
