Just replaced the transmission on my car and i double checked all wiring and everything. it won't start and the ignition is backwards when i go to try and start it nothing. i try to turn it off and take keys out it wants to turn over, accessories mode is still normal. i'm sure it will start once the anti-theft light is off, but i can't reset it until my ignition is fixed. My question is, what is causing my ignition to do the only thing i remember is the key was in the ignition when i hooked up the battery. does anyone have a wiring diagram making sure my grounds are hooked up correctly?
Jun 25, 2022 at 7:07 AM
