Will not shift out of first gear
RANDY MCKEE
  • 1998 PONTIAC GRAND PRIX
  • 3.8L
  • 6 CYL
  • 174 MILES
Hello, all I am looking at getting the car listed above with 3800 SC motor. The car runs and drives fine but it seems it won't shift out of first gear, reverse and all works. Could someone maybe know what it could be or please give me ideas on were to start to look if it's worth getting?
Saturday, February 16th, 2019 AT 8:24 PM
  • 109,951 POSTS
If it won't shift from first, it can be many different things. For example, a bad speed sensor or even a plugged cooler. However, other than guessing what it is, you really need to have the computer scanned to identify diagnostic trouble codes. Here is a quick video that shows how it is done:
https://youtu.be/YV3TRZwer8k
Also, check to make sure the fluid is clean and full. Do this first and let me know what you find. Here are the directions for checking it.
1. Start the engine and operate the vehicle for fifteen minutes or until the transmission fluid reaches an operating temperature of 82-93°C (1 80-200°F).
2. Park the vehicle on a level surface. Apply the parking brake and block the wheels.
3. While the engine is idling and with your foot on the brake pedal, move the shift lever through each gear range, ending in Park.
4. Check the fluid level, color and condition (transmission fluid conditions are diagnosed by color). The fluid will be higher on the fluid level indicator when the transmission is cold. Conversely, the fluid level will drop when it is checked at operating temperature.
5. If it is necessary to add fluid, DEXRON-III Automatic Transmission Fluid is preferred. DEXRON-III is an acceptable substitute.
Saturday, February 16th, 2019 AT 8:39 PM
RANDY MCKEE
Thank you so much. I will get back you soon!
Saturday, February 16th, 2019 AT 8:42 PM
