Starts and dies immediately after startup
16,000 MILES • 5.0L • V8 • RWD • AUTOMATIC
KEITH COFFMAN
Car will start up and die immediately after startup unless I give it gas and keep it over 2000 RPM's soon as I take off the gas it will die immediately what will cause this I already changed it IAC and the tab sensers.. no luck with either one of them I also around a code on it and came up with code 81 and 82 on an older code reader
Sep 21, 2016 at 4:17 AM
HMAC300
  • 48,601 POSTS
if this has not been modified like putting a carburetor on it check am 1 and am 2 solenoids for not working or a vacuum leak going to them.it can also be a bad ECM. there is no code 81.
Sep 21, 2016 at 10:54 PM
KEITH COFFMAN
Are they hard parts to get?
Sep 22, 2016 at 1:26 AM
HMAC300
  • 48,601 POSTS
no idea, check with rock auto .com they are online.
Sep 22, 2016 at 2:25 AM
KEITH COFFMAN
Okay thanks.
Sep 22, 2016 at 2:39 AM
  • 55,808 POSTS
Hey Keith
Here is a guide for en engine that stalls at idle check it out and get back to us so it will help others.
https://www.2carpros.com/articles/stall-at-idle
Please let us know what you find.
Best, Ken
Sep 25, 2016 at 1:06 PM
