Starts an runs just for a few seconds
150,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
SCOUT2494
  • 12 POSTS
i have replaced the fuel pump, fuel pump relay, fuel pump regulator and removed the fuel line before it goes in fuel filter. gas squirts very little. could it be the crank shaft sensor?
Nov 19, 2019 at 2:24 AM
  • 55,688 POSTS
Can I ask if the security light is flashing when you try to start the engine? If so this guide will help reset it:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Does the engine have spark this guide will help:
Nov 20, 2019 at 11:54 AM
SCOUT2494
  • 12 POSTS
there is no guides to go by?
Nov 20, 2019 at 12:03 PM
  • 55,688 POSTS
Did you click the links above?
Nov 21, 2019 at 4:39 AM
SCOUT2494
  • 12 POSTS
on the 2002 Subaru Outback 3.0 the crank senor is it located on top of the bell housing because it`s not under alternator?
Nov 22, 2019 at 8:38 AM
  • 55,688 POSTS
Here is the location of the crankshaft sensor and the instructions on how to replace it in the diagrams below. Check out the diagrams (below). Please let us know what happens.
Nov 23, 2019 at 2:57 AM
