Will not start in the morning
155,000 MILES • 4WD • MANUAL
MIKEA56
Although have excellent battery car will not start in mornings. Have to use 2000a jump starter. Once started it will start without charger all day long.
Oct 7, 2021 at 9:26 PM
Good morning,
I would start by having the battery load tested to be sure it is or has available power for it to run the starter.
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
Check the voltage of the battery in the morning. It should be 12.4 to 12.6 volts.
Oct 7, 2021 at 9:55 PM
