Starting trouble
275,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
MALEKASHIK
Hi i have indian made nissan sunny starting problem engine crank-but not start and some times engine is start but engine light is on and no acceleration.
Feb 12, 2021 at 3:13 AM
We need to start with checking for codes as it sounds like this is a fuel issue but we can get to that after we check for codes.
Then I would suggest we check fuel pressure and make sure it is okay.
Lastly here is a guide that will get us started on the possible other causes:
Let's start with this info and go from there. Thanks
Feb 13, 2021 at 7:16 AM
