Crank no start issue
94,500 MILES • 2.4L • 4 CYL • 4WD • MANUAL
DAVID HESS
When I try to start my truck it will not turn over. It has a crank to the truck but it just will not start. I am getting no fire under the hood. I was wondering if this sounds like a crankshaft senor went bad.
Apr 6, 2018 at 12:38 AM
  • 55,849 POSTS
Yes, that is the first place I would look. when these sensors go out they do not set a code most of the time. Here is a guide on what you are in for when changing the sensor out:
Here is the location of the crank sensor for your car (below).
Cheers, Ken
Apr 7, 2018 at 6:02 AM
