Starting the engine
PARK4321
  • 1995 HONDA ACCORD
  • V6
  • 4WD
  • 260,000 MILES
When turning the ignition I'm hearing the beginning sound of the crank but it is not turning over to start the engine, can you tell me what can be causing this?
Monday, September 5th, 2016 AT 10:24 AM
HMAC300
  • 48,601 POSTS
Check battery for condition including load test make sure terminal ends are clean on battery and if it has anti theft try resetting it or another key. Also check starter relay for corrosion
Monday, September 5th, 2016 AT 12:03 PM
PARK4321
Thank you, I will definitely look into that.
Monday, September 5th, 2016 AT 12:35 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Please let us know what you find so it will help others.
Best, Ken
Wednesday, September 14th, 2016 AT 6:03 PM
