When starting the car it clicks and loses all electrical power
146,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ANGELLO SWALLOW
When I turn the key to crank the car it just clicks and loses all electrical power. then I release the key back to the run position it the power comes back to the dash.
Feb 9, 2019 at 6:09 AM
Good evening,
Do you have a voltmeter to check the battery voltage?
Your battery may be too low to start the car.
Also, the cables being dirty can cause this as well.
I would start with checking the battery.
Feb 9, 2019 at 8:19 AM
