Intermittent no start when turning the key in the ignition
230,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
JOHN BREWIN
  • 5 POSTS
When starting by turning the key in the ignition sometimes it will start and sometimes it will not. The key turns and nothing happens as though it is not connected.what i have to do is take the key out of ignition and try again or put it in neutral and try and between doing that it will start eventually. The starter motor turns over strongly when it catches. Any ideas please?
Sep 19, 2020 at 1:19 PM
  • 110,248 POSTS
First, this vehicle isn't offered in the US, so I have no technical information. However, I will try my best to help.
When this happens and it refuses to start when in park, does it always start when you place it in neutral?
Sep 19, 2020 at 2:45 PM
JOHN BREWIN
  • 5 POSTS
Hi Joe,
No it does not always start in neutral. I take the key out of the ignition and put it back the other around (desperation) and go back to park and between them it will eventually start. Sometimes you turn the key and it will delay starting and then decide to start.It feels like you may a flat battery but then strongly turns over and starts.
John
Sep 19, 2020 at 8:39 PM
  • 110,248 POSTS
John,
If it eventually starts when you shift the gears back and forth, it could be the park/neutral safety switch is out of adjustment or bad.
I don't have a schematic to direct you, but are you familiar with what I am indicating?
Sep 20, 2020 at 10:21 AM
JOHN BREWIN
  • 5 POSTS
Thanks Joe.
I will check it out with my mobile mechanic guy and see if he knows how to fix it. Very frustrating playing Russian roulette every time you turn the key in the ignition if only I was a rich man as the song says. Cheers
John
Sep 20, 2020 at 11:25 AM
4DRTOM
  • 467 POSTS
I can put a little info on this.
This car is a GM product and is sold in the US, I believe as a Pontiac GTO. If you can upload a pic of the body and motor without its cover on it we can probably figure out what exactly it is here and get you the needed diagrams and other information needed to handle your occasional no start condition.
Tom
Sep 20, 2020 at 1:12 PM
