Would the ignition coolant control sensor keep it from starting? Because the prongs on mine are broke off.
Feb 20, 2017 at 4:41 AM
JDL
✓Experienced Mechanic
If you are talking about the coolant temperature sensor, if you unplug the sensor, it should start and run. Now a faulty signal from the sensor is another issue. Fix the sensor or electrical connector. How long since a tune-up? Any applicable trouble codes? At the top of page, repair guides, a lot of good information on that link.
Feb 20, 2017 at 4:58 AM
TRAVISCROWE7
MEMBER
No it is the ignition coolant control sensor, I have already replaced the sensor your talking bout and just did a tune up. I unplugged the sensor and still not starting I am not getting any codes.
Feb 20, 2017 at 6:35 AM
JDL
Other than the cts, I am not sure which sensor your talking about? If it cranks good but will not start, have a helper crank it while you check for spark at the spark plugs. If spark everywhere, use a gauge and check proper fuel pressure. Also, check fuel injector pulse.
