The car will not start. there is no problems with cranking or firing. I believe it to be a fuel issue, but the fuel pump is running fine and building good pressure. I have cleaned the carburetor and throttle body along with the fuel injector. It seems to be be getting enough gas, but will not crank which leads me to believe it may be a sensor problem.
Feb 19, 2017 at 4:11 AM
