Intermittent not starting issue
166,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JOHNWJR
Car won’t start periodically. Turn key on lights go out. Replaced ground cable. Had battery checked out. Battery is good. If I disconnect both cables from battery, then reconnect, car starts.can’t find reason for this to happen.
Jan 29, 2021 at 9:55 PM
SEVAG P
  • 405 POSTS
hello,
It sound like your battery clamps or the cables are the problem
check our link below perform the procedure as described.
Let us know what happens.
thank you.
Jan 29, 2021 at 10:26 PM
JOHNWJR
Changed battery, waiting to see if this happens again. ( correction- this was a 2004 Chevrolet Suburban)
Feb 5, 2021 at 1:07 AM
SEVAG P
  • 405 POSTS
yes we are intrested let us know what happens with you.
thank you.
Feb 5, 2021 at 5:36 AM
