Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Acadia
Engine
Symptoms
Not Running
Starting problems
2008 GMC ACADIA
180,000 MILES • V8 • 4WD • AUTOMATIC
JBLYKINS
MEMBER
1 POST
When I try to start it acts like battery is drained. If I pump gas a couple of times will start and run fine. Tested battery and it is good.
Feb 9, 2018 at 3:06 AM
Experienced Mechanic
Good afternoon.
Pumping the gas does nothing like it did with the old carburetors.
if you have to push on the accelerator, it may be the idle air control.
also, I would check the fuel pressure to be sure the pump is working and check for spark.
Feb 9, 2018 at 4:42 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
