Starting problems
180,000 MILES • V8 • 4WD • AUTOMATIC
JBLYKINS
When I try to start it acts like battery is drained. If I pump gas a couple of times will start and run fine. Tested battery and it is good.
Feb 9, 2018 at 3:06 AM
Good afternoon.
Pumping the gas does nothing like it did with the old carburetors.
if you have to push on the accelerator, it may be the idle air control.
also, I would check the fuel pressure to be sure the pump is working and check for spark.
Feb 9, 2018 at 4:42 AM
