Starting problems?
210,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
LIGHTS OUT2
I have a new battery, alternator and starter and every time that I have to start it, I have to jump the battery off with jumper cables and it is an everyday driver and does just fine once I get it started.
Mar 25, 2023 at 10:25 AM
  • 55,721 POSTS
This sounds like the positive battery cable, or you have a defective battery, here is a guide to help you test the battery without equipment:
If the battery passes, I would check for battery power at the main power lug when the key in is the crank position. This guide can help, if the test light has power and then it goes away the positive battery cable is bad:
Please go over these guides and report back.
Mar 26, 2023 at 11:46 AM
