when engine cools down hard to start after warmed up easy start.
Mar 13, 2018 at 9:44 PM
✓Experienced Mechanic
Good morning.
Does it crank normally when it is hard to start?
Mar 13, 2018 at 10:11 PM
JBONES
MEMBER
yea cranks over good. put new plugs, fuel injectors, and new egr valve. didn't replace the gas temperature sensor
Mar 14, 2018 at 8:01 AM
JBONES
MEMBER
when engine at room temperature cranks 8-10 revolutions once started it will start at the touch of the key
Mar 14, 2018 at 8:06 AM
Are there any codes??
Two things come to mind:
1. Coolant temperature sensor.
2. Intake air temperature sensor.
Mar 14, 2018 at 8:26 AM
JBONES
MEMBER
Here is what I did this morning. After about ten cranks engine started. I shut engine off immediately, waited one minute. started right back up. going to check for codes. almost acts like losing fuel pressure.
Mar 14, 2018 at 10:09 PM
Correct. I would start by checking the fuel pressure. leave the gauge on the car overnight so you can see if the system is losing prime.
Mar 14, 2018 at 10:16 PM
RENEE L
MEMBER
Hello JBONES,
Thank you for visiting 2CarPros. Here is a helpful link to an article from this site with step by step instructions and pictures explaining the process of checking the fuel system pressure, regulator and fuel pump in less than fifteen minutes:
