Intermittent starting problems
12,000 MILES • 1.0L • 3 CYL • 2WD • AUTOMATIC
PETER33
  • 7 POSTS
Sometimes car does not engage engine when key is turned on and foot brake is held down other times starts straight away.
Dec 24, 2019 at 12:53 AM
SCGRANTURISMO
  • 4,897 POSTS
When the starter does not engage what exactly does your do? Is there a click" Is the nothing at all? Or, is the a whining spinning sound?
Thanks,
Alex
2CarPros
Dec 24, 2019 at 5:57 PM
PETER33
  • 7 POSTS
When key is turned there is nothing. just like when you try to start the car when it is in gear. everything thing lights up but nothing else. thanks
Dec 25, 2019 at 12:24 AM
PETER33
  • 7 POSTS
The car is now starting as normal, but when it didn't the brake pedal did not depress slightly as it does when starting normally. also the car is a aigo mmt. thanks again .
Dec 25, 2019 at 12:41 AM
I am thinking there may be an issue with the brake booster. If these bleed down the pedal gets very hard to press. Glad it it working correctly at the moment. If you have further issues. Please come back to 2CarPros. Thanks
Dec 29, 2019 at 9:17 AM
PETER33
  • 7 POSTS
Thanks for the info and have a happy new year.
Dec 31, 2019 at 12:25 AM
Any time. Thanks for using 2CarPros. Happy new year to you as well.
Dec 31, 2019 at 11:38 AM
