starting problems
100,000 MILES • AUTOMATIC
AMY JO BROWN
the car will only start when I hear a faint buzzing noise located at the top part of the engine. when that noise is not there it wont start. when I turn the ignition the noise with come on. after driving it a while and then turn it off, ill try start it up again and it wont work. there recently has been a new fuel filter, spark plugs, idle air control valve and battery put in.
May 29, 2016 at 3:50 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts can scan and rent fuel gauge. check fuel pump relayit may be bad or going bad.
May 29, 2016 at 11:06 PM
RENEE L
  • 1,260 POSTS
Hi Amy,
Here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com. Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
https://youtu.be/YV3TRZwer8k
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
May 31, 2016 at 8:11 AM
