It started intermittently. Turn on key, try to start, get nothing. Put in drive then back in park and would start. Now I have broken gear shift lever. Besides that, changed out starter because that stopped working. Having same problem now. Starter clicks but that is it, it will not turn truck over. I know it is not the battery. Sometimes if I disconnect battery and hook back, the truck will start. Probably just luck. please help.
Nov 8, 2017 at 2:36 AM
