drove approximately five miles shut truck off would not turn over?
200,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
DENNIS NEWTON
have to jump to start alternator. checked out okay, new battery. after letting in run for a while drove approximately five miles shut truck off would not turn over. The amp gauge does not show it charging unless over 2000 rpm.
Feb 15, 2017 at 4:49 AM
This sounds like a drained battery again but we need to find out how you tested it that it passed.
Here are a few guides that will help with this testing that we need to do to the alternator and battery:
https://youtu.be/dCjmRL3p4Cs
I suspect the alternator has failed and when you are running it, it runs off the battery only and eventually drains the battery.
I attached the process below on how to replace the alternator as I suspect this is the issue.
Let us know what you find and we can go from there.
Thanks
Aug 7, 2021 at 11:37 AM
