Starting problem
16,000 MILES
MHDZ
I have a remote to vehicle to start. new batteries, but still wont start. all icons come on but seems like it wants to but does not. while inside when I press the remote the doors lock and unlock ? I tried to give jump didn't work. horn works, lights and radio? Do uou think it is starter or new battery? Or fuse? Just a women asking questions. help!!
Aug 22, 2019 at 3:59 AM
So just so I understand, the engine doesn't start with the remote start feature but it does start normally?
If just the remote start feature does not work, this could be a number of things that are preventing the start. It could be the hood ajar switch or a door switch. There are a number of other things that could prevent the remote start but if the vehicle won't start with the ignition either, then yes, it could be the starter.
Maybe getting a video of what is happening would help clear up what is happening.
Aug 22, 2019 at 7:00 AM
MHDZ
Hi, no it doesn't start either way? I'll check doors etc., to see if they are open. a friend said might be battery? But we shall see. I will let you know thank you kindly for input. if its starter I didn't get any warning signs like stalling. is that normal?
Aug 22, 2019 at 3:06 PM
If it doesn't start using the key then all of those issues are not your issue. Those would only prevent the remote start operation.
If the starter failed then that will not cause any issues like stalling. The only thing it will do is cause a no start. The starter is only used while the engine is cranking.
Here is a guide that will help explain what the starter is used for and what happens if it is not working:
Aug 23, 2019 at 10:28 AM
