After two days of rain the truck will not start. It takes more then one complete day of rain before it will not start. Will turn over but sounds like the distributor is 180 degrees out, coughs and back-fires. Had to replace the distributor due to the top plate rusted off the shaft. I think water is getting in the cap but cannot figure out how. Installed new cap and rotor and that fixed it for a month. It started to do it again. The two screens on the bottom of the distributor are clean and not plugged. No water runs through the hood seal and hits the cap that I can tell. What else can I look at to stop this problem? I purchased this truck new and it just started doing this about a year ago.
Mar 26, 2018 at 2:02 AM
