Engine cranks but does not start
220 MILES • 3.1L • V6 • 4WD • AUTOMATIC
MICHAEL LEONARD
Had shifting problem, got refurbished computer. Car turns over but wont fire. Car starts and shifts fine with obd plugged into old computer. Flagship one has flashed refurbished computer I sent it back they flashed it again. Car turns over but wont start. Is it me?
Jun 12, 2021 at 7:31 AM
  • 110,248 POSTS
I don't think it's you. If the vehicle won't start with the remanufactured computer, they flashed it again and it still doesn't work, the problem is in their computer.
Since your vehicle starts with the old computer plugged in, something isn't making sense to me either. Will they send you a different reprogrammed PCM?
What do you mean by the OBD plugged into the old computer? Do you mean that a scanner needs to be attached to the OBD port for it to run? If that's the case, you could be dealing with a ground-related issue that is being completed by the scan tool.
Jun 12, 2021 at 3:40 PM
MICHAEL LEONARD
My car starts with old computer but shifts rough, when I plug in obd (I don't search codes or press enter just plug it in) it shifts fine. Turns over with new computer but wont fire.
Jun 13, 2021 at 4:13 AM
  • 110,248 POSTS
It sounds like a ground issue simply because it shifts normally with the scanner attached. The only thing different is you are providing an additional ground path for the computer.
Do me a favor. Check on the rear of the intake. There is a ground strap located there. Make sure it is attached and in good condition. I believe it runs to the firewall from the engine/transmission bell housing.
Next, I attached the wiring schematic for the entire automatic transmission circuit. I highlighted a ground I would like you to check as well. I had to cut the pics in half to make them readable, but I did overlap them so you can follow from one to the next.
Let me know what you find.
Jun 13, 2021 at 11:57 AM
MICHAEL LEONARD
Motor is grounded to inner wheel well. still looking for firewall ground.
Jun 15, 2021 at 2:15 AM
  • 110,248 POSTS
Let me know if you find it. Also, when you locate grounds, make sure they are tight, clean, and free of corrosion or damage.
Jun 15, 2021 at 3:38 PM
