Vehicle starts does not start with the key, but will start with the remote
135,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
KAYCIE MOSHER
My truck doesn't do anything when I turn the key, but my viper remote start works fine. I am stumped. Also, I just had a tune up, starter replace, and a new fuel pump. When I got it back, it worked fine. My repair guy turned it on and off a bunch of times, no problems. I gave it a quick ride including a stop for a soda. It started fine there, and I stopped by my mechanic to tell him it worked good. He turns it off, then on, no start! We tried my remote, started fine. We think the problem is in the steering column, but what? My mechanic is stumped. Thanks for any answers you may have. PS, we have not looked for source of the problem yet.
Apr 3, 2019 at 11:19 AM
SCGRANTURISMO
  • 4,897 POSTS
This sounds like it could a problem with your vehicle's ignition switch. The Ignition Switch has a plastic arm that pushes a rod when you turn the key to push the switch, which looks like a box completing the circuits for the various systems the key controls. I have included in the diagrams down below directions for the removal and installation of your vehicle's ignition switch. Please go through these directions and get back to us with what you find out.
Thanks,
Alex
2CarPros
Apr 3, 2019 at 3:21 PM
