It sounds like you have one of three things happening; either you have a fuse that is out which there are a few that run the system or you have a bad ground to the BCM or the BCM is going out. Let's start with the easy stuff first checking the fuses numbers 8, 32, 3, 19, 21 and 7.
Here is a guide and the fuse and wiring diagrams diagrams to get us started:
Here is guide to help you check the BCM ground:
Here is how to check the PGM-FI relays:
If the BCM is bad you will need to have a garage program it for you.
Check out the diagrams (below).
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Images (Click to enlarge)
Dec 3, 2017 at 4:33 AM
