My car will not start. all lights are on dash board but will not kick on. The theft light is flashing also. What could it be?
Jan 17, 2018 at 5:50 AM
HARRY P
✓Experienced Mechanic
It is a shot in the dark but try having the dealership test the key. If it is a chipped key, which it probably is, then the chip could have been damaged/demagnetized. This would keep the car from starting and cause that light to flash, on and off.
Jan 17, 2018 at 11:27 AM
DON THE MECHANIC
MEMBER
1 POST
Put it in neutral start it then put it in drive
Feb 8, 2018 at 11:08 AM
HARRY P
^ That's a good idea. It could be a neutral safety switch/range switch gone bad or out of adjustment. Often times you can put it in neutral and it'll start, so definitely try that.
