Starting problem, battery keeps draining?
63,234 MILES • 4 CYL • 2WD • AUTOMATIC
BBOEHNE
Dead battery, got new one, started fine. Next start, nothing, no lights, sounds or cranking. Starts and runs when jumped, then dead...
Jun 15, 2024 at 12:45 AM
TY ANDERSON
  • 719 POSTS
Sounds like you have something draining the battery make sure the battery clamps are all tight you shouldn't be able to move them also. If there's any corrosion on a battery clamp you'll need to clean those off before installing the battery clamps.
Do you have anything plugged into any of the power ports that could be draining the battery.
If you don't have anything plugged in the power ports then this could be a plethora of electrical components causing this battery drain.
Jun 15, 2024 at 2:21 AM
BBOEHNE
Thanks. The negative clamp was broken - I have replaced it and am now charging battery.
Jun 15, 2024 at 3:01 AM
TY ANDERSON
  • 719 POSTS
Let us know what the outcome is. Thanks for the update.
Jun 15, 2024 at 6:09 AM
BBOEHNE
This was it! Works great.
Jun 17, 2024 at 7:52 AM
TY ANDERSON
  • 719 POSTS
That's good news! Thank you for letting us know!
Jun 19, 2024 at 12:26 AM
