Starting problem
240,000 MILES • 1.6L • 3 CYL • TURBO • 2WD • MANUAL
NIHAR RANJAN BARAL
Engine cranks but does not start. Pushed the car on third gear to crank the engine a little. After that switch on the ignition engine cranks and starts.
Jul 18, 2018 at 2:52 AM
  • 110,248 POSTS
There are a few things that will prevent your car from starting. Take a look through this link. It discusses reasons why it may not be starting.
Also, when it does not start, you should check to see if spark or fuel is missing. I feel you will find one is. Here are two links which describe how to check for both:
Let me know if this helps or if you have other questions. I will be glad to help.
Jul 19, 2018 at 12:04 PM
