Hi. I have the car listed above XLE model. The problem i have is it is not starting. It cranks and start for one or two seconds and then turns off. I also check it with the scanner there’s no code, but the vehicle ECM was not communicating with the scanner. I send the ECM for the repair but they said the ECM is fine. They said there should be something else with the car that’s why the vehicle is not communicating with the ECM. Please help, i can’t figure out the problem.
Jan 20, 2019 at 1:09 PM
