My car engine refuse to start after replacing it timing chain and timing chain's lower adjuster. what could be the problem?
Sep 1, 2017 at 5:00 AM
JDL
✓Experienced Mechanic
You may need to check cylinder compression? If that checks out, if it cranks good but will not start, have a helper crank it while you check for spark at the spark plugs, if spark everywhere, use a gauge and check proper fuel pressure and fuel injector pulse. Any applicable trouble codes?
