Starting problem
120,000 MILES • 1.9L • 4 CYL • TURBO • FWD • MANUAL
KUBEN GOVENDER
  • 5 POSTS
My vehicle starts okay in the morning after that takes longer to start. you have to keep acceleration pedal down and after a few swings while key kept in starting position it gets going.
Mar 3, 2017 at 10:13 AM
SATURNTECH9
  • 30,869 POSTS
Do you get any black smoke when it starts? Sounds like you could have a bad coolant temperature sensor.
Mar 4, 2017 at 5:53 AM
KUBEN GOVENDER
  • 5 POSTS
The caddy starts better but still have to keep accelrater pedal down and starts on second swing
Mar 7, 2017 at 11:02 PM
KUBEN GOVENDER
  • 5 POSTS
Tried new coolant sensor starts better but after two swings with accelerator placed flat down and swing for a little
Mar 7, 2017 at 11:18 PM
SATURNTECH9
  • 30,869 POSTS
Where was the sensor located you replaced?
Mar 8, 2017 at 4:53 AM
KUBEN GOVENDER
  • 5 POSTS
It has a two pin on one side and clips on the otherside it is near the water theremostat housing just used a screw driver to take out clip and unplug lug and then clip back on and place wire lug back 5mins
Mar 8, 2017 at 10:00 AM
SATURNTECH9
  • 30,869 POSTS
Is this a Diesel or Gasoline engine?I don't have any repair information on non USA model cars.
Mar 8, 2017 at 1:40 PM
KUBEN GOVENDER
  • 5 POSTS
Vw caddy 1.9tdi diesel motor 2006 model
Mar 8, 2017 at 2:14 PM
  • 55,691 POSTS
Please connect a code reader to the car to see if there are any codes.
Here is a guide that will help you.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Mar 13, 2017 at 5:04 AM
