Starting my engine
2,000,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
KEMOY28
  • 28 POSTS
My car cranks but will not start, it has very strong fuel pressure, brand new fuel pump and fuel filter, has good spark, brand new coil and spark plugs and new air filter,I get pulse at injectors with a test light and still no start. What else can I check?
Aug 29, 2016 at 9:48 AM
WRENCHTECH
  • 20,760 POSTS
You are missing something there.
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
4) If all of these things check good, then you would need to do a complete compression test.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
Aug 29, 2016 at 10:38 AM
KEMOY28
  • 28 POSTS
All those info listed above turned out to be fine on this engine, i did used an incorrect sensor from a different engine on the water neck where the temperature sensors are... Could that be the problem? The sensor i used is from a nissan engine and the car did ran with it
Aug 29, 2016 at 3:02 PM
WRENCHTECH
  • 20,760 POSTS
If it really passed all those tests, the car would be running. That is a systematic method to isolate the cause of the no start.
If you have doubts about the sensor, then use a scanner to read the temp from the computer and see if it is correct.
Aug 29, 2016 at 9:28 PM
KEMOY28
  • 28 POSTS
Turned out my car was flooded... But now it seems to burn rich... Black/brown smoke comes from the tail pipe when accelerating
Sep 3, 2016 at 4:34 PM
WRENCHTECH
  • 20,760 POSTS
That's a good reason to verify the temp sensors with a scan tool
Sep 3, 2016 at 9:27 PM
KEMOY28
  • 28 POSTS
I've changed the sensor
Sep 7, 2016 at 1:57 AM
  • 55,732 POSTS
It sounds like it could be a bad injector causing the system to go full on, here is a guide hat will help you
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Let us know what you find
Sep 14, 2016 at 10:25 AM
