Shuts off while driving will not restart until cooled
138 MILES • 1.8L • 4WD • AUTOMATIC
SHARELE
Basically runs good when it gets to a certain point, but shuts off at stops, and chugs to get going, then at a certain point will run good, but then shuts off and won't start until cool down.
there is a leak in radiator that i am dealing with and know that is added problem.
May 30, 2019 at 3:10 AM
  • 110,251 POSTS
Welcome to 2CarPros.
This could be several issues. For example, engine vacuum leak, fuel pressure issue, bad crankshaft position sensor and so on. What I need you to do is scan the computer for diagnostic trouble codes. This vehicle has an OBD 1 system, so no special tooling is required other than a short jumper wire or even a paper clip.
Follow the directions in this link and let me know what you find.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
I will watch for your reply.
May 31, 2019 at 11:54 AM
