Will not stay running after engine swap
80,000 MILES • 2.5L • 4 CYL • TURBO • 4WD • AUTOMATIC
RYANJOE01
I have the vehicle listed above XT jdm swapped the engine I rebuilt myself . I am having an issue; I crank the car then it starts then shuts off instantly. I can run it on starting fluid into the throttle body . I have fuel pressure, good spark since it will run . I am stuck I need input. I will add a video to help you better understand.
Feb 3, 2020 at 10:30 AM
  • 110,248 POSTS
If it runs on starting fluid then it isn't getting fuel. Is there a security system in the vehicle and if so is the light staying on?
Next, I need you to check for an injector pulse. Here is a link that explains how it is done:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Feb 3, 2020 at 12:35 PM
