Yeah I've tested the battery of tests with alternator. I've tested the starter. I'm still having issues for when the vehicle is running if I turn on the lights the car shuts off. I've tested for shortages in the amperage I found out that the ACC backup fuse was drawing power I pulled that once I turned on the lights it was fine for 2 to 3 minutes I turned off the lights turn them back on the car shut off again. what do I need to do?
Nov 30, 2019 at 1:28 AM
