Starting issues
130,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
MATTHEWALFEREZ
I replaced steering ignition, reset anti theft. also replaced crank shaft sensor. it does not start with key. only if I start through relay it only cranks over. I am at a loss don't know what it could be.
Jun 4, 2019 at 2:13 AM
STEVE W.
  • 15,409 POSTS
How did you do the anti-theft reset? What does the theft light do when you turn the key to run? How about start? What was the reason for changing the key? The same thing where it wouldn't start with the key?
Jun 5, 2019 at 9:33 AM
