Starting issues usually will not start, after a second start?
111,800 MILES • 6.2L • V8 • 4WD • AUTOMATIC
CARA SWANSON
slower “turnover” after an initial start.
usually won’t start, after a second start.
next attempt usually is “delayed” and weak but will start.
Alternator is fine.
Battery was replaced last year, gauges look fine, connectors too.
"Service battery charging system” message displayed once.
No loss of electrical systems/no warning lights.
It has made the sound like the doors were locking while trying to start it.
Also, the check traction control and service suspension system messages are on. Traction control doesn’t work.
Nov 20, 2022 at 11:05 AM
  • 55,710 POSTS
These are two separate problems we will handle the hard starting issue on this post please start a new question for the traction control issue.
This problem sounds like a weak or defective battery which can happen, or you have corroded or loose battery cables.
Here are two guides that can help us fix the problem:
and
Please go over these guides and report back.
Nov 21, 2022 at 2:07 AM
