Starting issues
170,000 MILES • 4.6L • V8 • RWD • AUTOMATIC
GREGORY E. MAXWELL SR.
Car will not start at times. Sometimes it will start. It is a hit and miss on starting. Changed starter relay, no help. Any help please.
Jul 31, 2017 at 8:55 AM
  • 55,748 POSTS
I assume that sometimes the engine will not crank over is this correct? If so then I would suspect the starter motor itself is going bad.
Use a test light to check for power at the starter solenoid (small wire)
Here is a couple guides to get you started, check out toward the bottom.
https://www.2carpros.com/articles/car-engine-will-not-crank-over
You will need to jack the car up.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Cheers, Ken
Aug 2, 2017 at 7:38 AM
